dukebravo
#1 Posted : Friday, May 30, 2014 4:54:03 AM(UTC)
dukebravo
I appreciate any advice. I've got a Monogram that is running non-stop, and thefresh food (and perhaps freezer) side is too cool. After overnight cooling, the temps are usually 0/25 when set for 0/34. I ran diagnostics and it shows all thermistors passing, and running the damper test I can hear the damper moving but I haven't opened the unit to do a visual. When I set the temp control for 5/38 degrees - the compressor turns off, the compressor fan continues running (perhaps a cool down mode?) but after a few minutes it kicked back on even though the temps were only 0/30 degrees. So the thing wants to cool even below set temps. Next steps?
Thank you
#2 Posted : Friday, May 30, 2014 3:41:04 PM(UTC)
I would try a new motherboard, assuming the thermistors check ok.
