justschecking
#1 Posted : Friday, October 14, 2011 3:56:35 AM(UTC)
justschecking
The door on the dishwasher has lost resistance when opened. The door would fall hard if I did not control the weight. Is the spring broke or hydraulic system failed? Is this something I can fix? Any help would be appreciated.
#2 Posted : Friday, October 14, 2011 4:22:36 AM(UTC)
Replacement parts for KUDM01FK models | AppliancePartsPros.com
You are short a couple digits in the model number.
See section 7 for the parts of the door spring mechanism.
Remove the kick plate and take a look.
To repair it you may have to pull the unit forward a foot or so.
I cannot say if you can fix it as it depends on your mechanical ability but is is not that complicated.
justschecking
#3 Posted : Friday, October 14, 2011 5:37:59 AM(UTC)
justschecking
Thanks for the help. I have ordered the parts and will soon be making the repair.
palmetto flyer
#4 Posted : Monday, December 5, 2011 3:36:17 PM(UTC)
palmetto flyer
I replaced the outer door on my GE Profile model GSD5120D01BB. The new skin was much better quality and heavier gauge metal. Unfortunately, now the door falls heavily unless you guide it down. The springs are both still attached and apparently in good shape. Is there an adjustment or heavier spring available? Thanks in advance. PF
#5 Posted : Tuesday, December 6, 2011 1:59:42 AM(UTC)
palmetto flyer
Here is the install sheet, take a look at page 4.
http://products.geapplia...DF&Name=31-30515.pdf
Miele dishwasher door doesn’t stay down (Dishwasher Repair)
by Guest 11/20/2022 6:28:07 PM(UTC)
GE Quiet Power II Dishwasher door spring (Dishwasher Repair)
by Guest 9/21/2022 5:12:33 PM(UTC)
Change Bosch Dishwasher Door to panel ready (Dishwasher Repair)
by DLo 8/27/2021 6:50:07 PM(UTC)
Whirlpool dishwasher door leak (Dishwasher Repair)
by Guest 5/26/2021 9:40:52 AM(UTC)
Fell on Dishwasher Door - Snapped (Dishwasher Repair)
by chingyland 4/15/2021 2:48:10 PM(UTC)
Dishwasher door help (Dishwasher Repair)
by Meileo 10/24/2020 8:18:49 AM(UTC)
SOLVED: Dishwasher door leak (Dishwasher Repair)
by raulk 7/4/2020 12:48:46 PM(UTC)
GE Dishwasher Door open issue (Dishwasher Repair)
by lookingfor 4/27/2019 2:59:24 PM(UTC)
GE GDF570SSF0SS Dishwasher Door Leak (Dishwasher Repair)
by Ericsd2 1/2/2019 2:17:44 PM(UTC)
Bosch Dishwasher Door Falling (Dishwasher Repair)
by mcnicollwj 1/21/2018 8:39:25 PM(UTC)
Whirpool Dishwasher door squeaks (Dishwasher Repair)
by chiefpokagon 9/2/2016 6:37:09 AM(UTC)
dishwasher door leaks (Dishwasher Repair)
by lavern1935 12/1/2015 12:14:41 PM(UTC)
GE Monogram Dishwasher Door Bottom Splash Guard (Dishwasher Repair)
by jaybeegee 11/17/2015 5:59:21 AM(UTC)
Bosch Dishwasher Door Won't Close (Dishwasher Repair)
by fswallis 3/26/2015 4:30:35 PM(UTC)
KitchenAid dishwasher door leak (Dishwasher Repair)
by edburnsmd 3/23/2015 4:03:39 PM(UTC)
