rogerstreetman
#1 Posted : Wednesday, October 12, 2011 10:14:42 AM(UTC)
rogerstreetman
the ice dispenser motor turns counter clockwise and should be turning clockwise.
#2 Posted : Wednesday, October 12, 2011 1:58:54 PM(UTC)
What is the complete model number of the refrigerator?
rogerstreetman
#3 Posted : Wednesday, October 12, 2011 3:06:33 PM(UTC)
rogerstreetman
mod # ASD2624HES
Amana
#4 Posted : Wednesday, October 12, 2011 8:22:49 PM(UTC)
This motor is reversible and should turn in both way depending on how the power comes to the motor. Why do you believe it should turn CW only?
here are the breakdown diagrams and Replacement parts for AMANA ASD2624HES REF - SXS/I&W | AppliancePartsPros.com
rogerstreetman
#5 Posted : Thursday, October 13, 2011 5:07:16 AM(UTC)
rogerstreetman
two things are happening.
the auger is being forced out of the end plate where the motor connects and the ice crusher arms are rotating so the back of the blades are doing the crushing.
the motor is a ac motor and i do not think you can change the direction by reversing the power leads.
#6 Posted : Thursday, October 13, 2011 9:52:25 AM(UTC)
Check the wiring diagram and component specifications. The Tech sheet is attached to the reply.
File Attachment(s):
16026206 - ASD2624HES.pdf (244kb) downloaded 24 time(s).
