Dishwasher Model #GU1200 XTLS1. After reading blogs I thought replacing the Electronic Control Assembly (#AP3775964) would work but having done that the problem still exists. Can you help?
on the front panel the following lights bling: Delay Start hour 4, Normal Wash Cycle & Cancel
Dishwasher will not start.
Thanks Ray
Thanks for your reply. The panel black and I suspect the part number appears to be AP3176980 - if that is correct I will order one. Please let me know.
Ray
Yes Ray. The part number you posted is correct.
