2 Pages12>
jdc0430
#1 Posted : Friday, December 12, 2008 7:23:16 AM(UTC)
jdc0430
Did Amana make 2 different Overloads in 2003? I have attached the photo to show what I am talking about. Here is the transcript from the help center:
**Update:
So, I don't know where to get this other Overload. I plugged the new one in without plugging in the piece that won't fit and air is circulating, but I don't know how safe it is.
I have an Amana refrigerator I purchased in March of 2003. The model number is ARB224RCW and the serial number is 10013868CV. The diagnosed problem was a relay and I was told that part # 12555902 would fix it.
Problem is, I took the part to the Maytag store along with that specific part number and they are not identical
It plugs directly into the refrigerator, but the power supply doesn't fit
Dave: Click here for part info
Jonathan: Yes, I have looked at this picture and it is what I got from the Maytag store
Jonathan: It does not work on my refrigerator
Jonathan: everything on my Overload is the same as this part except the right hand plug
Jonathan: mine requires a plug for 2, not just one as pictured
Dave: One moment please
Jonathan: thank you
Jonathan: this is what my piece looks like:
Jonathan:
Dave: Based on the model number you provided that is the correct part for your appliance.
Jonathan: I understand
Jonathan: but it still doesn't fix the fridge
Jonathan: I was told there was a special order required by Maytag for the one prong
Jonathan: they don't have a 2 prong
jdc0430 attached the following image(s):
libertyappl
#2 Posted : Friday, December 12, 2008 7:37:39 AM(UTC)
libertyappl
Look at this part Part Details - MAYTAG Overload/relay, part number: 67002527
This one looks like it will fit your plug.
Nat
jdc0430
#3 Posted : Friday, December 12, 2008 8:01:59 AM(UTC)
jdc0430
From the looks of it, I believe you found it. I am incredibly thankful. You have save me $160 (potentially)
libertyappl
#4 Posted : Friday, December 12, 2008 8:09:07 AM(UTC)
libertyappl
Glad to help!! Although according to the parts breakdown he first one posted is supposed to be the correct one. That doesn't mean somene hadn't switched it along the way.
Nat
jdc0430
#5 Posted : Friday, December 12, 2008 11:39:14 AM(UTC)
jdc0430
Yup! WORKED!!! THANK YOU SOOOOOOO MUCH!!!!!!! I have no idea why he would charge $160 for parts and labor, but this plug and play was easy :)
Jonathan
libertyappl
#6 Posted : Friday, December 12, 2008 1:07:52 PM(UTC)
libertyappl
Glad you got it fixed!!
Nat
russtuff
#7 Posted : Friday, January 9, 2009 7:49:55 AM(UTC)
russtuff
which overload do you need? The one on the left side of the photo (with two connectors) or on the right (with one-piece connector)?
Russ
libertyappl
#8 Posted : Saturday, January 10, 2009 6:51:28 AM(UTC)
libertyappl
Jim_S
#9 Posted : Sunday, January 30, 2011 7:42:24 AM(UTC)
Jim_S
It looks like there might be a 3rd make:
Part Details - WHIRLPOOL Overload, relay, part number: AP4078361
UserPostedImage
Any idea what the difference might be between them? I have the same problem on an Amana ARB2217CB. The APP cross references show that ARB2217CB, ARB2517CB and ARS2661BB all use the same replacement compressor and capacitor, but each lists a different relay (two with the connector shown, but the one for me is the one with the connector that won't fit.) I could see different model to fit different wiring harnesses, but
Part Details - WHIRLPOOL Overload/relay, part number: AP4077400UserPostedImage
only seems to differ from the one above by the color of the dot (and the one I ordered doesn't even have one.) Depending on the model, these are all used with the same compressor and capacitor. Any ideas on differences? Are they safe to interchange? My main concern is if they might have different points where teh overload kicks in, but they are listed for use on the same compressors. ...very confusing. Any advice would be much appreciated.
In another thread, the recommendation was to cut the harness and use the listed replacement, but I hate to do that if it's just a hiccup in the parts database.
Jim
#10 Posted : Sunday, January 30, 2011 11:28:36 AM(UTC)
All these start devices must provide an internal klixon and a PTC device to provide cold start current (5- 10 ohm cold) to the compressor start winding, usually the bottom left pin.They must be compatible with the compressor pin out. If not, the suppliers would be in serious trouble. Only difference is the refrigerator plug might be different. They all must provide the run capacitor pins to allow the capacitor to plug into.
2 Pages12>
