alexc
#1 Posted : Tuesday, January 6, 2009 8:27:18 AM(UTC)
alexc
The washer will run a cycle ok but then restarts the cycle. If the door is closed it will restart itself randomly trying to rerun the last cycle. Keeping the door open is the only way to disable the beast. The cancel button seems to work but then eventually the cycle begins again.
#2 Posted : Wednesday, January 7, 2009 12:59:34 PM(UTC)
Did you see any lights on the control panel blinking?
alexc
#3 Posted : Wednesday, January 7, 2009 2:31:12 PM(UTC)
alexc
Yes, the Normal Cycle light randomly
comes on by itself and the last time we tried to run a cycle the Normal Cycle light was flashing at about a 1 cps rate. It would not complete the cycle but with multiple cancels we eventually got it to drain.
Alex
#4 Posted : Thursday, January 8, 2009 1:50:42 PM(UTC)
Looks like the Normal Cycle pad is stuck. The control panel has to be replaced. In order to provide the right part number I need the color of the control panel.
alexc
#5 Posted : Thursday, January 8, 2009 3:10:08 PM(UTC)
alexc
The control panel color is "Biscuit". Thanks Gene for your input on this problem. Is there a tech sheet or some reference that would provide some clues on the change out of the control panel?
Alex
#6 Posted : Friday, January 9, 2009 4:16:47 PM(UTC)
Alex,
The part number for the console is AP3176439
Open the door and remove all screws around the inner panel. Remove the inner panel. Remove the control board cover. Remove the control panel ribbon from the control board.
alexc
#7 Posted : Thursday, January 15, 2009 2:52:49 PM(UTC)
alexc
Gene,
The part has been changed and the unit is now working normally. Thanks for your diagnosis and repair notes.
Alex
#8 Posted : Thursday, January 15, 2009 7:19:33 PM(UTC)
You are welcome. I'm glad you were able to fix it.
