Dave2
#1 Posted : Thursday, October 6, 2011 9:57:09 AM(UTC)
Dave2
I have an older electric dryer that has developed a starting problem. Lately when I push the start button, it spins the motor, but doesn't catch and keep moving. If I hold down the button for more than about a ten count, the motor stops spinning entirely. If I wait a couple minutes and try again once or twice, the motor usually starts running on it's own, but lately I've been having trouble with that working. Is it the motor?
Joe / APP Team
#2 Posted : Thursday, October 6, 2011 10:50:21 AM(UTC)
Joe / APP Team
Dave,
Sure sounds like an older, weak motor,and belt.
If you can get access to a multimeter, Check for a minimum of 105 VAC on the L1 leg at the terminal block, when you press the start button. If the voltage stays above 105 VAC you'll need a motor and belt.
Thanks,
Dryer start problem (Dryer Repair)
by brokedryer 1/13/2014 3:47:25 PM(UTC)
dryer start problems (Dryer Repair)
by JHN 2/19/2013 7:30:28 AM(UTC)
14 mo old GE dryer start problem (Dryer Repair)
by donab429@yahoo.com 9/11/2012 7:18:52 AM(UTC)
Electric Dryer Start Problem (Dryer Repair)
by Homemaker 11/19/2007 7:09:39 AM(UTC)
