vtrike
#1 Posted : Sunday, January 4, 2009 8:23:34 PM(UTC)
vtrike
This should be easy for some one who has worked on this machine. It's a maytag commercial dryer and I cant see how to get the cabinet apart. Someone suggested I take off the coin holder and there was a nut . Well there was but it didnt seem to release the top. Any ideas. or where I might find a repair manual. I guessed at the age because it is in the apartment where I live.
Thanks for your help.
libertyappl
#2 Posted : Monday, January 5, 2009 6:45:31 AM(UTC)
libertyappl
here's a parts breakdown
Model MDE10CSACW
Nat
vtrike
#3 Posted : Monday, January 5, 2009 6:50:08 AM(UTC)
vtrike
Thanks for the breakdown. Would still appreciate knowing how to get it apart.
#4 Posted : Monday, January 5, 2009 6:49:12 PM(UTC)
Try this: remove the screw on each side on the bottom of the front panel. Grab the front panel on the bottom and lift it up till about 45° to release it from the top fasteners. Open the diagrams and you'll see what to do next.
vtrike
#5 Posted : Monday, January 5, 2009 8:10:28 PM(UTC)
vtrike
Thanks Gene, I will give it a try in the morning, If I tried it now I might get kicked out for waking some one up.
thanks again, hope it works.
VErn
vtrike
#6 Posted : Thursday, January 8, 2009 5:19:22 AM(UTC)
vtrike
I see why Gene is a senior expert. This was the awnser I needed. It worked like a charm. Now I just have to figure out what the noise is.
Thanks again.
vtrike
#7 Posted : Thursday, January 8, 2009 3:45:58 PM(UTC)
vtrike
My problem was a bad blower wheel, it was out of round and loose on the shaft. Thanks for your help. Vern
#8 Posted : Friday, January 9, 2009 4:48:48 PM(UTC)
You are welcome. We are glad you were able to fix it.
Guest (4)
Whirlpool LDA7600W0 Cabinet Removal (Washer Repair)
by rudyrudy 3/27/2013 1:47:53 PM(UTC)
Whirlpool cabinet removal (Washer Repair)
by scott1980 1/14/2011 3:04:57 PM(UTC)
gE wASHER CABINET REMOVAL (Washer Repair)
by CAROLEANNE411 8/16/2010 2:56:06 PM(UTC)
by rnhent12 8/13/2009 8:05:19 AM(UTC)
by beadyiwoman 5/28/2008 5:30:46 PM(UTC)
Cabinet removal (Washer Repair)
by jumbyway 8/23/2007 9:33:21 AM(UTC)
