Sandiinflorida
#1 Posted : Wednesday, October 5, 2011 6:41:04 AM(UTC)
Sandiinflorida
Water dispenser slowed and then stopped completely. When you push the dispenser, you can hear it trying to pump out water but not a drop comes out. The same thing happened about a year ago to the ice maker unit. The ice maker will not fill with water.
Anyone who can help me? Is it 2 DIFFERENT valves? Solenoid? Pump?
Oh, brand new filter installed recently. I thought maybe the filter was the reason for the water slowing but it worked for couple days after filter, then stopped. Not a drop will come out.
#2 Posted : Wednesday, October 5, 2011 10:17:21 AM(UTC)
Try to use the refrigerator without the filter as described in the User manual, page 6.
Post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL ED5FHEXNS00 REFRIGERATOR | AppliancePartsPros.com
Sandiinflorida
#3 Posted : Wednesday, October 5, 2011 10:37:41 AM(UTC)
Sandiinflorida
tried that, took out the filter and no go. It makes the sound that you are gonna get water but not a drop comes out!
#4 Posted : Wednesday, October 5, 2011 11:30:25 AM(UTC)
Make sure there is a good pressure in the incoming water line.
If there is nothing wrong, replace the water inlet valve on the back of the refrigerator.
- The water inlet valve Part number: AP3160649
Sandiinflorida
#5 Posted : Wednesday, October 5, 2011 12:04:33 PM(UTC)
Sandiinflorida
would that have been the part that stopped flow of water into the ice maker months ago? In other words.......first water stopped going into the ice maker (I have been filling with bagged ice from the store, it still dispenses and crushes ice) and now no water from the water dispenser.
Are there TWO valves? Or, if I replace this part should I expect both ice and water to work?
#6 Posted : Wednesday, October 5, 2011 1:58:20 PM(UTC)
As you can see on the picture, there are two solenoids. So, very likely it will do it.
Guest (4)
water dispenser stopped working. No light no pwer (Refrigerator & Freezer Repair)
by waterdispprob 11/19/2023 10:08:39 AM(UTC)
@! Kitchenaid KBSD612ESS00 Screen, Ice & Water Dispenser Stopped Working !@ (Refrigerator & Freezer Repair)
by davenlei 6/9/2022 9:11:16 AM(UTC)
Fridge ice and water dispenser stopped working (Refrigerator & Freezer Repair)
by Vbackman 12/19/2013 10:47:22 AM(UTC)
Maytag Ice/Water Dispenser Stopped Working (Refrigerator & Freezer Repair)
by Lori328 7/31/2012 3:49:25 AM(UTC)
Side Door Ice/Water Dispenser Stopped Working (Refrigerator & Freezer Repair)
by JBed 6/24/2010 10:20:48 AM(UTC)
by barbjustin 4/8/2010 6:55:31 AM(UTC)
GE - Water Dispenser Stopped Working (Refrigerator & Freezer Repair)
by toofast 12/14/2009 10:28:43 AM(UTC)
Whirlpool Fridge Water Dispenser stopped working (Refrigerator & Freezer Repair)
by kabibby 6/26/2009 1:01:48 PM(UTC)
Freezer & Water dispenser stopped working (Refrigerator & Freezer Repair)
by Rosier1975 12/9/2008 8:00:20 AM(UTC)
