tinkerbell63
#1 Posted : Tuesday, October 4, 2011 3:21:59 AM(UTC)
tinkerbell63
I have a GE Top load washer Model WLSR3000G1WW. it will fill and drain water but will not spin or agitate.
My husband has bypassed the inline fuse & lid switch. Still will not agitate. Other things he has tried: belt is on and looks fine. can freely move where the belt is and it turns the agitator inside the washer.
the green light blinks about once every 9 seconds.
last time washer was run, the lid was opened in the final spin. it usually slows down on its own, but continued to spin with the lid open.
sidfink43
#2 Posted : Wednesday, October 5, 2011 5:02:37 PM(UTC)
sidfink43
It seems like you are not getting error messages from the inverters, so the most likely problem is the control unit. Try changing it out and see if that helps.
tinkerbell63
#3 Posted : Monday, October 10, 2011 6:38:58 AM(UTC)
tinkerbell63
The washer does not have a error screen on the front. where else would the error messages be?
sidfink43
#4 Posted : Monday, October 10, 2011 1:44:27 PM(UTC)
sidfink43
The error codes are generated by a blinking light on the motor.
tinkerbell63
#5 Posted : Tuesday, October 11, 2011 3:27:08 AM(UTC)
tinkerbell63
the green light blinks once every 8-9 seconds
sidfink43
#6 Posted : Tuesday, October 11, 2011 3:41:48 AM(UTC)
sidfink43
Ok, try resetting it using the instructions that are here
HydroWave GE Washer Repair Guide
Ge Washer Wont Agitate Or Spin (Washer Repair)
by cameo591 11/19/2010 3:31:06 PM(UTC)
