onthebay
#1 Posted : Monday, January 5, 2009 4:06:01 PM(UTC)
onthebay
HI,
Icemaker was frozen solid. I heard a clicking sound; like the knives are trying to cut the slab into cubes but it's not able to, so the water kept running and the obvious mess occured. I was advised it was time to replace the assembly on another forum. I did so with a part MAC D7824706Q I just purchased from this site. Now there is no water running. (yes, the water is turned back on and the actuating arm is down).
Please help.......thanks
#2 Posted : Tuesday, January 6, 2009 6:53:15 PM(UTC)
Make sure the wire harness plugged all the way into the ice maker and the water feeding tube into the ice maker is not frozen.
