rosepetal
#1 Posted : Monday, January 5, 2009 4:59:30 AM(UTC)
rosepetal
Hi. My oven has been burning everything and we just figured out it's because its not turning off even when it reaches the adequate temperature - I had to disconnect the gas to get it to stop heating when I last turned it on. The broiler and everything else is working fine, though. Any ideas?
#2 Posted : Monday, January 5, 2009 6:22:36 PM(UTC)
Did you try to unplug the range to stop heating before you turned the gas "off"?
rosepetal
#3 Posted : Tuesday, January 6, 2009 4:44:02 PM(UTC)
rosepetal
Yeah, I even unplugged the range and even then the oven wouldn't turn off, not till I actually disconnected the gas. I then plugged it back in and the oven top and broiler work fine, but as soon as I turn the oven on it won't turn off.
#4 Posted : Wednesday, January 7, 2009 7:30:35 PM(UTC)
Most likely the problem is a relay on the control board which stuck closed. In order to provide the right part number for the control board I need the color of the touch pad and a digit after "S" in the model number.
rosepetal
#5 Posted : Sunday, January 11, 2009 8:18:31 AM(UTC)
rosepetal
The only digit I see after the model number is Series "3" and the touch pad is mostly black (some gray buttons)
rosepetal
#6 Posted : Saturday, January 17, 2009 4:57:31 AM(UTC)
rosepetal
Gene, thanks for you r help so far but did you get this last bit of information you asked about?
#7 Posted : Saturday, January 17, 2009 3:31:32 PM(UTC)
Sorry for the delay. The part number for the control board is AP3085520
