TexJoybell
#1 Posted : Monday, September 26, 2011 6:33:36 AM(UTC)
TexJoybell
My dryer only heats on one cycle but that one cycle doesn't heat very well. I have to run the load 3-4 times before its dry. I'm trying to figure out what part or parts I need to get so I can get my dryer working right.
Thanks for your help!
#2 Posted : Monday, September 26, 2011 12:17:51 PM(UTC)
Replacement parts for WHIRLPOOL LER5636LQ0 | AppliancePartsPros.com
I am not sure about this unit. Is the above the way it is supposed to work or is it that some heat cycles are not working.
If not working which ones work and which do not.
The most common cause for having to use multiple cycles is a vent problem.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer's vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
Note: The above is not recommended for gas dryers due to carbon monoxide concerns.
TexJoybell
#3 Posted : Monday, September 26, 2011 8:02:14 PM(UTC)
TexJoybell
The only cycle that kind of heats is the automatic high heat cycle. I have 2 cycles that don't heat at all, automatic low heat and the timed drying cycle.
I will have my husband try the vent thing this weekend and see if that helps. But I think it's something else.
#4 Posted : Tuesday, September 27, 2011 12:36:37 AM(UTC)
See the attachment for your wiring diagram.
At the top of my list would be the timer.
Unplug the unit and one wire to the Timer Switch 2 contacts.
Then measure across the contacts with a meter.
Set it to where it does dry, the meter should read 0 ohms.
Then set it to the cycles that do not work, they also should read 0 ohms.
If not the timers is toast.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
LER5636.pdf (333kb) downloaded 3 time(s).
Guest (5)
Gas dryer not working properly after power outage (Dryer Repair)
by Frazierfam5 3/7/2016 4:43:32 PM(UTC)
Dryer not working properly (Dryer Repair)
by gdmcc1955 8/5/2014 9:59:33 AM(UTC)
