TomJ
#1 Posted : Sunday, January 4, 2009 11:15:00 AM(UTC)
TomJ
My dryer was running, but would not heat up. I unplugged the unit and removed the rear panel. I found one wire connected to the 'High Limit Dryer Thermostat' to be melted off the connector. I'm thinking this is an easy fix; trim the burnt end off the wire, crimp on a new connector, and re-attach to the original thermostat. I'm wondering, however, why did this happen? Is it common? If I make this repair will it happen again or possibly cause a bigger problem? Any suggestions or expert opinions will be appreciated.
#2 Posted : Sunday, January 4, 2009 12:21:53 PM(UTC)
Could be that there was a connection problem from day one.
If the connector was not properly crimped there is some resistance between the wire and the connector. This acts the same as a heating element and heats up as current passes through it. The wires start to corrode which increases the resistance which increases the heating etc. etc.etc. Till finally the connection fails.
Cut back the wire until you get to nice clean copper.
Make sure you get a good crimp onto the wire with the new connector.
Make sure the connector you use is rated for high current.
Make sure the thermostat lug is good and clean. If it is pitted or cannot be cleaned properly replace the thermostat.
KERS206XSS1 thermostat replacement part (Oven Repair (including Ranges and Cooktops))
by Guest 1/23/2024 3:59:52 PM(UTC)
Freezer thermostat replacement (Refrigerator & Freezer Repair)
by vasiliy 7/14/2020 7:16:41 PM(UTC)
refrigerator thermostat replacement part difference (Refrigerator & Freezer Repair)
by scirugby 12/8/2016 8:37:36 PM(UTC)
whirlpool thermostat replacement (Refrigerator & Freezer Repair)
by jmeag 6/16/2015 4:51:28 PM(UTC)
KitchenAid range thermostat replacement (Oven Repair (including Ranges and Cooktops))
by sterling05 9/5/2013 7:32:24 PM(UTC)
Defrost thermostat replacement (Refrigerator & Freezer Repair)
by tommyrob 1/22/2013 2:41:36 PM(UTC)
Haier Freezer Thermostat Replacement (Refrigerator & Freezer Repair)
by Rick5472 9/17/2012 6:05:27 AM(UTC)
temp thermostat replacement (Refrigerator & Freezer Repair)
by chrisg1 7/21/2011 3:34:13 AM(UTC)
Oven Thermostat Replacement (Oven Repair (including Ranges and Cooktops))
by lmckelvy 10/21/2010 12:15:38 PM(UTC)
whirlpool ed25rfxfw01 thermostat replacement (Refrigerator & Freezer Repair)
by tippywanknobi 7/6/2010 7:51:44 AM(UTC)
Hotpoint Oven thermostat replacement (Oven Repair (including Ranges and Cooktops))
by mcqueary 11/20/2009 9:28:00 AM(UTC)
Refergator Thermostat Replacement Part (Refrigerator & Freezer Repair)
by RNRAUTOGLASS 8/20/2009 8:22:26 AM(UTC)
by kelly b 6/23/2009 1:06:33 PM(UTC)
by jerryallen 5/16/2009 7:36:17 AM(UTC)
GE electric range thermostat replacement (Oven Repair (including Ranges and Cooktops))
by Arnie 3/18/2009 8:38:23 AM(UTC)
