John765
#1 Posted : 16 years ago
John765
Hi
I'm having a problem with my Olsen furnace, the pilot light will light and then go out and will keep doing this until I turn off the furnace at the main power shutoff. The burner will not light. I think its the gas valve but i'm not sure. Any help with this would be great
John
ernesto1959
#2 Posted : 16 years ago
ernesto1959
if it hold it ...cicle on may be ok....if pilot keeps shuting off , is time to get new thermocouple.
SublimeMasterJW
#3 Posted : 16 years ago
SublimeMasterJW
Probably a contaminated flame sensor. The brains of your furnace needs confirmation of ignition. If it fails to recieve a capcitance change in the sensor then it shuts down and continues to retry ignition. Check this out:
Central Gas Furnace Quickly shuts down ‎(SublimeMasterJW's Appliance Advice‎)
Gas valve short cycling? (Oven Repair (including Ranges and Cooktops))
by stubborn1 about a year ago
Robert Shaw Fireplace Gas Valve - Sticks (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest about a year ago
GAS VALVE OR IGNITOR? (Oven Repair (including Ranges and Cooktops))
by JAMES B HOOKS 4 years ago
Maytag MGD9700SQ0 Won't Heat/Open Gas Valve (Dryer Repair)
by jpc315 4 years ago
HELP! Whirlpool Dryer Gas Valve (Dryer Repair)
by Steve60 5 years ago
Whirlpool Gas Range won't light: gas valve shuts off after 1 or 2 seconds (Oven Repair (including Ranges and Cooktops))
by Drew42TX 6 years ago
Replacing dryer gas valve (Dryer Repair)
by T-Rex 8 years ago
New Gas valve and Ignitor (Oven Repair (including Ranges and Cooktops))
by wellshii 10 years ago
No power to flame sensor, gas valves, or ignitor (Dryer Repair)
by ms0674 11 years ago
Changed gas valve and dryer still not working (Dryer Repair)
by Manaus 11 years ago
How do I test gas valve coils? (Dryer Repair)
by Dmalone1949@gmail.com 11 years ago
No power to ignitor or gas valves (Dryer Repair)
by dougL 11 years ago
Access to Gas Valve - Maytag stackable (Dryer Repair)
by Defens 12 years ago
Gas valve wire cap broke off (Oven Repair (including Ranges and Cooktops))
by repairnoob1 12 years ago
Gas valve replacement? (Dryer Repair)
by denne20 12 years ago
