6 Pages123>»
butch1954-1963
#1 Posted : Saturday, January 3, 2009 8:58:33 AM(UTC)
butch1954-1963
fills then stops emits smell of belt slipping it does spin & empty
butch1954-1963
#2 Posted : Saturday, January 3, 2009 9:09:47 AM(UTC)
butch1954-1963
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
#3 Posted : Sunday, January 4, 2009 3:50:08 PM(UTC)
Remove the front panel and check both belts. Check the pump belt tension as described in the Service Manual (page 3-31). Remove both belts and check if they are glazey on the sides and/or leaving a black marks on your hands, then most likely they are worn out.
Turn the transmission pulley CW to check if it's locked up. If it is, then the transmission has to be replaced.
Here are the break down diagrams for the Maytag washer Model A5000
jesus freak
#4 Posted : Thursday, January 3, 2013 8:29:21 AM(UTC)
jesus freak
Pulled up this thread. I have a 21 year old A5000. It fills w/ water,but does not agitate. I pulled the front panel, but I do not see any belts. I reached underneath the front and got black from the belt on my fingers. I turned the belt and the transmission turned ( if the transmission is the part underneath the tub). Do I need a belt?
#5 Posted : Thursday, January 3, 2013 11:00:50 AM(UTC)
Hello,
Use the troubleshooting instructions from the previous post. If you will decide to replace a belt, then you have to replace both of them at the same time.
- The belt kit Part number: 12112425
Here are the breakdown diagrams and Parts for Maytag A5000 - AppliancePartsPros.com
File Attachment(s):
Pump belt adjustment.doc (51kb) downloaded 5 time(s).
jesus freak
#6 Posted : Thursday, January 3, 2013 12:16:28 PM(UTC)
jesus freak
I just replaced both belts, and the pump is pumping but no agitating. I can smell rubber burning, but no smoke. The troubleshooting link will not open.
#7 Posted : Thursday, January 3, 2013 2:07:13 PM(UTC)
...Turn the transmission pulley CW to check if it's locked up. If it is, then the transmission has to be replaced...
Did you do it?
jesus freak
#8 Posted : Friday, January 4, 2013 5:30:32 AM(UTC)
jesus freak
Yes! It turned. And the washer ran yesterday. I am at work now, and my wife calls me and says she smells burning rubber. I'm thinking its still the old rubber in the pulleys. Anyway, do you know the timing of events? ( fill, circulate, agitate)
It filled yesterday, then the motor turned the pump, & then it started to agitate. Is this correct? How long should the pump run before it begins to agitate?
#9 Posted : Friday, January 4, 2013 2:45:20 PM(UTC)
...then the motor turned the pump...
What did you mean? Did it drain at that time?
Did you adjust the pump belt tension after you replaced the belts?
jesus freak
#10 Posted : Friday, January 4, 2013 4:13:49 PM(UTC)
jesus freak
The belt adjust itself. It worked fine today on Permanent Press cycle.
6 Pages123>»
