BC1988
#1 Posted : Thursday, January 1, 2009 4:09:24 PM(UTC)
BC1988
I replaced the heating element and was going to replace the thermostat. Then noticed I that the timer was not advancing as it should. Everything else seems to check out okay, should I continue and replace the timer and/or thermostat?
BC1988
#2 Posted : Friday, January 2, 2009 1:00:51 AM(UTC)
If the timer will not advance on any cycle your timer needs to be replaced.
I usually pull the cover off to check for bad contacts. Sears calls for two different timers for this dryer. I would get the timer part # printed on the timer and order it.
BC1988
#3 Posted : Friday, January 2, 2009 4:02:01 PM(UTC)
BC1988
Electric dryer: will not heat and the timer quit working
Model Number: 110.62202100
Brand: Kenmore
Age: 5 - 10 years
BC1988
Thank you, will check the timer.
BC1988
