Pump seems to be working fine (I can hear it). Does not appear to be any obstruction in the drain line. Pump assembly was replaced less than 6 months ago - continual problem with dishwasher not draining. Any ideas? Thanks
Disconnect the drain hose from an air gap on top of the sink (if there is one) or from the garbage disposer, if there is no an air gap. Put this end of the hose in a bucket and run the drain cycle. Post the results.
Gene. What is the complete model number of the dishwasher?
There suppose to be 6 or 7 digits after 665. The complete model number if on the door frame.
