sholmer963@aol.com
#1 Posted : Sunday, November 16, 2008 2:54:12 PM(UTC)
sholmer963@aol.com
What does the code E1 F5 mean? If it means door lock do I need to change the lock motor and if I do how do I get to it if the door is locked and won't open.
libertyappl
#2 Posted : Sunday, November 16, 2008 3:08:25 PM(UTC)
libertyappl
1. If door latched:
[LIST=1]
  • Disconnect power from unit.
  • Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  • Replace door switch.
  • Re-apply power.
  • Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.[/LIST]Nat
  • tfine
    #3 Posted : Thursday, January 1, 2009 12:51:29 PM(UTC)
    tfine
    Thanks very much. This advice worked for me.
    libertyappl
    #4 Posted : Friday, January 2, 2009 4:26:58 AM(UTC)
    libertyappl
    Glad it helped!
    Nat
