What does the code E1 F5 mean? If it means door lock do I need to change the lock motor and if I do how do I get to it if the door is locked and won't open.
1. If door latched:
[LIST=1]
Disconnect power from unit. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C. Replace door switch. Re-apply power. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.[/LIST]Nat
Thanks very much. This advice worked for me.
