klinnk
#1 Posted : Wednesday, December 31, 2008 1:57:05 PM(UTC)
klinnk
I just replaced burned out oven element. All controls act like they are operating normally, but no heat. indicator lights come on. I checked the resistance temperature detector and it had right reading.
libertyappl
#2 Posted : Wednesday, December 31, 2008 7:08:22 PM(UTC)
libertyappl
Does the cook top heat?
Nat
klinnk
#3 Posted : Thursday, January 1, 2009 5:03:37 AM(UTC)
klinnk
The cook top works fine.
libertyappl
#4 Posted : Thursday, January 1, 2009 8:00:42 AM(UTC)
libertyappl
Check your wiring going to the element and the control board.
klinnk
#5 Posted: : Friday, January 2, 2009 1:17:01 PM(UTC)
klinnk
I checked the wires. Ihave 123 volts on each leg. With the oven controls off, I have no voltage at the elements. With the oven controls on, I have 123 volts at each of the element terminals, both the bake element and the broil element.
Frigidaire oven won’t heat (Oven Repair (including Ranges and Cooktops))
by Jseeders 6/16/2024 10:23:51 AM(UTC)
Frigidaire oven issue (Dishwasher Repair)
by Guest 5/8/2024 12:45:18 PM(UTC)
Frigidaire oven diagram control board (Oven Repair (including Ranges and Cooktops))
by Guest 1/22/2024 10:28:10 AM(UTC)
Frigidaire Oven Heats but Randomly Shuts off (Oven Repair (including Ranges and Cooktops))
by Guest 10/1/2022 7:32:55 AM(UTC)
Frigidaire oven won't stay lit (Oven Repair (including Ranges and Cooktops))
by Guest 7/31/2022 6:36:11 PM(UTC)
Frigidaire oven door hinge not locking (Oven Repair (including Ranges and Cooktops))
by jacobrobbins219 3/16/2021 5:42:08 PM(UTC)
Frigidaire Oven Preheats, but doesn't keep heat (Oven Repair (including Ranges and Cooktops))
by ben99 12/16/2020 12:49:23 PM(UTC)
My Frigidaire oven doesn't hold temperature in bake mode but does in convection mode (Oven Repair (including Ranges and Cooktops))
by rph812 8/24/2020 3:25:59 PM(UTC)
Frigidaire oven element (Oven Repair (including Ranges and Cooktops))
by Rhauck 5/24/2020 3:32:51 PM(UTC)
FPEH3077RFC - Frigidaire Oven Intermittent Temperature Issues (Oven Repair (including Ranges and Cooktops))
by pahey 1/15/2020 4:06:14 PM(UTC)
frigidaire oven wont heat after self clean (Oven Repair (including Ranges and Cooktops))
by chalooch101 10/14/2019 5:04:21 AM(UTC)
Frigidaire oven inoperable (Oven Repair (including Ranges and Cooktops))
by imabeanct@aol.com 1/31/2018 7:52:02 AM(UTC)
Frigidaire oven (Oven Repair (including Ranges and Cooktops))
by cpolk 10/6/2017 7:35:11 AM(UTC)
Frigidaire Oven bake option not working Igniter won't light (Oven Repair (including Ranges and Cooktops))
by mlb7412 9/30/2016 7:02:20 AM(UTC)
New Frigidaire oven Control Panel/Board - wiring help (Oven Repair (including Ranges and Cooktops))
by IGoofed 11/16/2015 8:06:12 PM(UTC)
