D.Shima
#1 Posted : Tuesday, December 30, 2008 9:18:27 PM(UTC)
D.Shima
I've read a few similar posts but mine differs slightly and with that hopefully will result with an easy fix. I have a GE Profile w/ the freezer on the bottom (sans French Doors). A couple weeks ago my fridge started warming up and decreasing the temp proved futile. I spoke to a repairman and he recommended before he came out to do a full defrost, so i unplugged the unit for a day and voila!, the fridge works, but after a week its now starting to warm again.
I noticed today as the fridge started to warm the freezer started to drop in temp. There is no excessive ice build up in the freezer and a fan is running. I do not hear a fan when i open the fridge. If the fan fridge is bad, then why would it work after a full defrost? Any help would be much appreciated.
Duane
libertyappl
#2 Posted : Wednesday, December 31, 2008 5:33:26 AM(UTC)
libertyappl
The ice is probably behind the rear panel in the freezer. The problem could be the defrost thermstat (aka thermosdisc) or the defrost heater or the control board.
