I Have A White Westinghouse Dryer That Is 12 Years Old And Has Worked Great Up Until The Other Day. Two Weeks Prior To It Not Heating It Was Making A Loud Squeal Noise While It Ran. I'm Not Sure If It Is A Belt That Needs Replaced Or The Fuse, Which The Dryer Book Says It Might Be. I Looked On A Parts List And I Don't Even See A Fuse But I Do See Belts. Should I Try The Belt First? Is It Connected To The Heating? Thank You
