c_willy
#1 Posted : Tuesday, December 30, 2008 7:55:38 AM(UTC)
c_willy
I push the dishwasher door closed and it does not latch at all, meaning I can pull it open without any resistance and do not have to push the door handle button up.
Also, I don't think this is the problem at all, but the door handle is easily moved up and down and does not appear to have a spring on it (if it's even supposed to in the first place).
I opened up the control panel and looked at the mechanism. I tested out the switch by pushing the button for the switch all the way down, heard it click, and then started up the dishwasher for a moment (while the door was open). The dishwasher started up so the switch is working fine. Problem is I can neither close the door securely nor get the switch button to be fully pressed down when the door is closed.
Is there a problem with the latch...or the strike plate on the tub...or a switch actuator(I have no clue what that is, by the way). Please tell me what part(s) I need to buy from your site to get this working. Thanks so much for your assistance.
I included some pictures. Not sure if they will be of any assistance, but hopefully they help you to diagnose the problem.
c_willy attached the following image(s):
c_willy
#2 Posted : Friday, January 2, 2009 8:11:13 PM(UTC)
c_willy
After doing some more investigating and looking over the diagrams for my model, I found out I was missing part #8269111 (Strike).
I ordered the part, took less than a second to install it, and now the door closes securely and the dishwasher works fine.
Even though no one on this forum helped me really, I would still like to thank the moderators for making this resource available and I'm sure that if I hadn't solved my own problem, someone here would have let me know what part I was missing. Thanks.
