i replaced the kit as per instructions,lower thermostat first part 3390291.but i was left with 1 unattache red wire.is this normal:confused:
Not sure what you mean. If the wire you refer to was part of the kit then perhaps it was not required in your unit. If the wire is part of the units wiring harness then you have miswired in the kit. Here is the part you mentioned. Click on the picture and read the questions/answers, perhaps one of them will help. Part number: AP2973862
THIS FORUM IS DEAD!!!!!!! |
