AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Maytag Gas Dryer will not heat up fully - princeton
The gas flame does not stay on for more than 20 seconds at any given cycle. As a result, the air temperature in the exhaust duct (near filter screen) does not exceed 110 degrees and the the dial does not proceed in the cycle. Drying of clothes takes forever - if at all.
Replaced both the high-temp thermostat (Ap4036956) and MuliTemp Thermostat (307250). Also, ensured that the air duct/screen is completely clear.
Replace the coils on the gas valve.[URL="http://www.applianceeducator.com/partshtm"][/URL]
Thanks,
However, I did one more experiment where I disconnected the dryer exhaust from the external exhaust duct. The dryer worked perfectly. The flapper was blocked and lint clogged the exhaust duct. I learn something new all the time.
Dryer Repair
