marinefish
#1 Posted : Friday, December 26, 2008 12:54:26 PM(UTC)
marinefish
The flame on my dryer shuts off after about 3-4 minutes and does not come back on until it sits for a few minutes and is turned back on. If you set it for a half hour or so it will run, the flame will go off and the dryer will continue to run with no flame and not dry the cloths.
I have replaced the following: #32 radiant sensor 338906, #9 Internal-bias thermostat 8318268, #7 thermal fuse 3392519, #15 thermostat 205*F 3403140, #4 ignitor 686590.
After replacing all of these parts it still will not keep the flame going longer then about 3-4 minutes. What other parts can I replace that will fix the problem? Thanks, George
Drags1998
#2 Posted : Friday, December 26, 2008 2:26:07 PM(UTC)
Drags1998
Replace the solonoids on the gas valve, I have seen many of then that will fire the first time and then not again until fully cooled down.
