Hello. I'm having problems with my Kenmore oven and hope someone here can help. It is a Kenmore 30" electric drop in range, model # 9114554590. Problems initially started when we noticed that it was not heating to the temp that we selected. Then last week, we turned it on and noticed that the bake element was glowing in one spot and spitting sparks. We found the element was broke in two pieces. I replaced the bake element with a new one and am still having the problem of not heating to the temp that is selected. Could I have a bad sensor? How do I run a diagnostic test on the oven? Thanks for any help...
Originally Posted by: kelgun ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hello. I'm having problems with my Kenmore oven and hope someone here can help. It is a Kenmore 30" electric drop in range, model # 9114554590. Problems initially started when we noticed that it was not heating to the temp that we selected. Then last week, we turned it on and noticed that the bake element was glowing in one spot and spitting sparks. We found the element was broke in two pieces. I replaced the bake element with a new one and am still having the problem of not heating to the temp that is selected. Could I have a bad sensor? How do I run a diagnostic test on the oven? Thanks for any help... Hi, what was your resolution? I have a similar problem with my 10 year old Kenmore oven.
