tedems
#1 Posted : Friday, December 26, 2008 6:45:37 AM(UTC)
tedems
Bought safety valve AP2131109 (3203459). Now when oven ignites flames shoot above the oven bottom about a foot. Gets to 400 degrees in less than a minute. I'm presuming this is not normal. Looking at the old valve and the new . The old valve looks as if it has a smaller orifice than does the new. Did they send me a Nat gas? The old orifice also sits low from the base of the valve than the new. Should i send it back for replacement? what should i do
#2 Posted : Friday, December 26, 2008 1:13:17 PM(UTC)
What kind of gas supply is used for the oven? All parts for gas appliances are sold for natural gas only everywhere in US.
tedems
#3 Posted : Saturday, December 27, 2008 5:04:31 AM(UTC)
tedems
Its a LP gas feed. The information on the sticker of the new valve says liquid propane.
#4 Posted : Saturday, December 27, 2008 12:21:43 PM(UTC)
Originally Posted by: tedems Go to Quoted Post
...The old valve looks as if it has a smaller orifice than does the new. Did they send me a Nat gas?...
A bigger orifice is for natural gas and this is the only way how such parts sold. In case if appliance has to be converted to LP all manufacturers used a conversion kit which usually included a different (smaller) orifices.
The part number for this safety valve does not have any references about LP gas. This is very interesting and I appreciate if you can post this sticker.
P.S. Very likely this range has been converted by someone else.
tedems
#5 Posted : Saturday, December 27, 2008 2:05:52 PM(UTC)
tedems
This is a zip file. The "G-LP" info is easily seen.
File Attachment(s):
gas valve.zip (73kb) downloaded 8 time(s).
#6 Posted : Saturday, December 27, 2008 4:08:45 PM(UTC)
The sticker on the gas valve says "G-LP .5 P.S.I." which means "1/2 PSI max inline pressure" and nothing else. This is standard for all domestic gas ranges.
tedems
#7 Posted : Saturday, December 27, 2008 6:01:27 PM(UTC)
tedems
What do i do with what i've got?
#8 Posted : Saturday, December 27, 2008 6:25:57 PM(UTC)
Try to use the orifice from the old valve.
Guest (5)
