PART #AP3796835 - Blue half of Valve has two small terminals. Red half ofvalve has two larger terminals. Which wires connect to which terminals? Apigtail wire asmbly contains a red wire and a doubled-blue pair. Pigtailconnects to Red half of valve, but which way? Red wire toward middle of valve?Or red to outer terminal? Two separate wires (one white, one blue) connect toBlue half of valve. Does White wire connect to inner or outer terminal? (be right back)
They are not polarity sensitive.
Originally Posted by: richappy  They are not polarity sensitive. So it doesn't matter, as long as I connect the pigtail asm to the Red side, and the separate blue and white wires to the Blue side. Correct ? Thanks, mtt
