Doris
#1 Posted : Monday, December 22, 2008 6:00:09 AM(UTC)
Doris
My oven clock and timer work but when I press start the oven displays the lo symbol and the degree as is normal for the preheating but then nothing more happens ...I hear the familiar click as if the oven was heating up but nothing happens ..it doesn't go beyond that stage.
#2 Posted : Monday, December 22, 2008 2:40:47 PM(UTC)
Hi Doris,
The model number you posted does not come up. Verify and repost it.
Doris
#3 Posted : Monday, December 22, 2008 5:04:20 PM(UTC)
Doris
Hi Doris,
I doubled checked and that is the correct model # wbw30521 serial # xc1901080
Thank you
Doris
#4 Posted : Monday, December 22, 2008 8:58:24 PM(UTC)
Doris,
If the model number is correct then it is just too old and not published on-line.
Is the oven gas or electric? If you can make and post a few pictures of inside and outside of the unit it might help for better advise.
Doris
#5 Posted : Tuesday, December 23, 2008 11:30:46 AM(UTC)
Doris
The oven is electric and about 15 years old.
Doris
#6 Posted : Thursday, December 25, 2008 12:18:00 PM(UTC)
Pull the heating element out, remove the wires from the terminals and check the heating element for continuity and for 120VAC between these wires while the control calls for heat. Post the results. Are you able to post pictures?
Doris
#7 Posted : Saturday, December 27, 2008 9:42:10 AM(UTC)
Doris
My huband pulled put the elements and found that to be working but there appears to be little votage going to the elements ..very low votage. What do you think would cause this would it be the timer or the switch???
#8 Posted : Saturday, December 27, 2008 12:39:51 PM(UTC)
Doris,
My answers are very limited and are not as accurate as I would like due to lack of the wiring diagram. Guessing is not the way I'd like.
Guest (4)
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Whirlpool Oven - Controls Don't Work (Oven Repair (including Ranges and Cooktops))
by Guest 3/25/2024 10:18:22 AM(UTC)
Multiple failures in Whirlpool oven? (Oven Repair (including Ranges and Cooktops))
by Guest 3/22/2024 6:55:50 AM(UTC)
Whirlpool Oven WFE770H0FZ2 (Oven Repair (including Ranges and Cooktops))
by Guest 2/9/2024 7:03:09 AM(UTC)
Whirlpool Oven GBD307PDS7 Shuts down and Upper Blower fan does NOT work (Oven Repair (including Ranges and Cooktops))
by rswilson1844 12/3/2023 11:18:33 AM(UTC)
Whirlpool Oven Cooling Fan (Oven Repair (including Ranges and Cooktops))
by Tfastle 11/21/2023 9:59:51 AM(UTC)
Whirlpool oven - only one heating element? (Oven Repair (including Ranges and Cooktops))
by smithhead 11/3/2023 2:42:01 PM(UTC)
Whirlpool Oven Temperature Low (Oven Repair (including Ranges and Cooktops))
by topthumb 1/23/2023 11:37:05 AM(UTC)
Whirlpool oven WFE505W0HB2 (Oven Repair (including Ranges and Cooktops))
by Guest 1/7/2023 5:44:02 AM(UTC)
Whirlpool oven broil element doesn't go off and code F3 E2 (Oven Repair (including Ranges and Cooktops))
by Right_to_Repair 3/29/2022 1:54:22 PM(UTC)
Whirlpool oven approximately (2006) (Oven Repair (including Ranges and Cooktops))
by Guest 2/28/2022 3:02:09 PM(UTC)
Whirlpool oven shuts off overnight (Oven Repair (including Ranges and Cooktops))
by Guest 4/15/2021 3:53:14 PM(UTC)
Kitchen Aid/whirlpool oven does not light on the first try (Oven Repair (including Ranges and Cooktops))
by Deintinis 11/22/2020 7:42:29 AM(UTC)
Whirlpool oven won’t stay lit (Oven Repair (including Ranges and Cooktops))
by jc0786 11/15/2020 7:11:47 AM(UTC)
Whirlpool Oven - RBS307PVS03 - Fuse for front control (Oven Repair (including Ranges and Cooktops))
by lmagdaleno 11/8/2020 11:50:57 AM(UTC)
