jjgundy
#1 Posted : Wednesday, August 24, 2011 12:03:40 PM(UTC)
jjgundy
I've got a whirlpool dyer that was working fine and now it will not start. Here is all the information I have on it.
MOD # LER4634PQ0
SER # MSO412623
TYPE D433-ELE-2406028-FM54
I'm wondering if the push button switch might have failed possible. I took the back covers off everything and could not find any loose or damaged wiring. Is there any known issues that this dyer might have with this type of thing? I apprecaite any help that you can provide to help me get this thing working again. I've got some laundry I've got to do and I hate to go to the laudry mat if I don't have too. LOL!!
Jesse
#2 Posted : Thursday, August 25, 2011 9:30:02 AM(UTC)
Replacement parts for WHIRLPOOL LER4634PQ0 29" ELECTRIC DRYER | AppliancePartsPros.com
A common cause of this is the thermal fuse on the blower wheel (Item 19 in Section 3) has blown.
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
jjgundy
#3 Posted : Friday, August 26, 2011 8:01:44 AM(UTC)
jjgundy
Thanks for getting back to me on this. I appreciate it.
I took the two light blue wires that were on the fuse and tapped them together and it still wouldn't work. I tested the fuse as well and it gave me a reading of .5 or .6 if I remember correctly. Is there anything else I could try? Could the switch on the dash board be the problem?
Thanks in advance for any other help you can provide.
Jesse
#4 Posted : Friday, August 26, 2011 12:56:26 PM(UTC)
See the attachment for the wiring diagram.
If it has an interior light, does that work?
OR
Check the power between Neutral and L1, should be 120 volts.
Other things to check are the door switch and the push to start switch.
Then the BK/BU contacts on the timer.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
#5 Posted : Friday, August 26, 2011 12:58:19 PM(UTC)
Looks like the attachment did not get included so here is another try at it.
File Attachment(s):
LER4634.pdf (333kb) downloaded 28 time(s).
Guest (4)
Whirlpool dryer stopped working LER7646EQO (Dryer Repair)
by mcf57 10/14/2011 4:26:32 AM(UTC)
Timer on Whirlpool Dryer stopped working (Dryer Repair)
by J Kreimer 2/5/2011 1:27:21 PM(UTC)
Whirlpool dryer stopped working (Dryer Repair)
by rloquist 3/29/2008 10:27:45 AM(UTC)
