5 Pages«<2345>
gboydfishin
#31 Posted : Sunday, July 18, 2010 6:40:58 AM(UTC)
gboydfishin
Originally Posted by: gboydfishin Go to Quoted Post
Thank you sir,
Part is ordered and I will let you know!
Gary
Hello again,
Ice maker installed and LIFE IS GOOD.
Thanks again,
Gary
#32 Posted : Monday, July 19, 2010 6:52:19 PM(UTC)
You are welcome Gary. I'm glad you were able to fix it.
hydrantman
#33 Posted : Tuesday, June 21, 2011 3:02:09 PM(UTC)
hydrantman
Hi I have the Kitchenaid Model KSRP25F and my Icemaker is not working. The LED light will blink twice quick and repeat itself help please!!:)
#34 Posted : Tuesday, June 21, 2011 6:25:49 PM(UTC)
The model number you posted is incomplete. Verify and repost it please.
hydrantman
#35 Posted : Wednesday, June 22, 2011 3:23:21 AM(UTC)
hydrantman
Sorry not a repair guy, found this number on the inside of the refrigerator door could not find any other numbers, any help would be thankful.
#36 Posted : Wednesday, June 22, 2011 4:44:34 PM(UTC)
Hopefully the Model Number Locator will help you.
wdmiller
#37 Posted : Wednesday, August 24, 2011 8:48:30 AM(UTC)
wdmiller
Hello,
I have a KitchenAid, KSRP25FNSS00 with ice and water through the door. Water through the door works fine. The ice maker stopped producing ice 2 days ago. Defrosted the water inlet tube, as I have had to do a couple of times before over the past 5 years of having this refrigerator. Plus, it did one time discharge water, which caused the ice tray to be overfilled, plus froze. Thawed and removed all ice from the ice tray and let the maker do it's thing. Still no ice. The LED status, will flash twice, pause, and repeat with the door open and flipper in "open" position. With the flipper closed, the LED is on solid. Ice ejector fingers are pointed almost straight up.
In reading all the earlier posts here, I suspect that it's either an optics unit, or the ice maker unit itself. Or if I'm missing something else to look at, or check, please advise.
Thank you in advance for your assistance.
W.D.
#38 Posted : Thursday, August 25, 2011 7:41:30 PM(UTC)
W.D.
Most likely the problem is a bad water inlet valve on the back of the refrigerator.
- The water inlet valve Part number: AP3160649
rvinvents
#39 Posted : Tuesday, July 10, 2012 5:53:10 PM(UTC)
rvinvents
Hello there Gene,
Your posts have been most helpfull already, Thank you!
This "ice maker not working" is on a Kitchenaid Superba Model KSRG25FKSS16 - My trouble shooting has determined that the optical ice sensor is working fine. By jumping L to V the water valve did open and water was flowing. The big questions begin when jumping T to H there is no motor movement and when looking for 120 V between N and L there was no current shown? There is power between white and black in the wiring harness coming out of the freezer wall.
Suggestions or part #'s please?
Thanks again,
Gary
hi gene i have the same ice maker and when i test n to L i have 7 volts ac cont tested harness is good test harness from freezer wall 106 volts ac any ideas?
#40 Posted : Tuesday, July 10, 2012 7:08:03 PM(UTC)
Make sure the shut off arm is down. If it's not the issue, replace the ice maker.
Kitchenaid icemaker not working (Refrigerator & Freezer Repair)
by gmpfeffer 2/24/2013 1:42:19 PM(UTC)
Kitchenaid Icemaker not working (Refrigerator & Freezer Repair)
by Stekelenburg 12/12/2012 9:55:44 AM(UTC)
kitchenaid icemaker not working (Refrigerator & Freezer Repair)
by Kewoldt 12/3/2011 7:13:17 PM(UTC)
by Dan54 2/28/2011 11:39:01 PM(UTC)
KitchenAid icemaker not working (Refrigerator & Freezer Repair)
by Anilkumar15 12/31/2010 5:44:41 PM(UTC)
by jjjacek 6/5/2010 4:45:22 AM(UTC)
Kitchenaid Icemaker Not Working (Refrigerator & Freezer Repair)
by Doug_dallas 6/8/2009 2:00:59 PM(UTC)
5 Pages«<2345>
