The machine was not in use and it started to beep. The time says 28 min. If I press start or stop it does nothing. If I unplug it the same thing happens. Is it the control board?
:confused: Originally Posted by: lhoven  The machine was not in use and it started to beep. The time says 28 min. If I press start or stop it does nothing. If I unplug it the same thing happens. Is it the control board?
