barney
#1 Posted : Friday, December 19, 2008 5:20:04 AM(UTC)
barney
After the bake temp. buton is pressed and a bake temp set, the setting just blanks out and the oven refuses to light up. If all the stove burners are lit up, and after a few more attempts to get the oven going, does it finally light up and works normally after.
#2 Posted : Friday, December 19, 2008 1:19:54 PM(UTC)
Most likely the problem is a bad control board (aka clock). In order to provide the correct part number I need the serial number of the range.
Here are the break down diagrams for the Admiral range Model 686AJ-TKSVW
