microwave over stove will not power up. i have250 volts to what looks like the ac/dc power converter but no dc voltage going down to circuit board. Anyone know how to test ? Micro is completely dead
Originally Posted by: brian anth microwave over stove will not power up. i have250 volts to what looks like the ac/dc power converter but no dc voltage going down to circuit board. Anyone know how to test ? Micro is completely dead I have the same problem with a GE JKP62G K3. First the control panel was dead. Replaced the 15 amp fusestat behind it. The control panel came back to life. I reset the clock - all good. When I started the microwave, the fuse popped again. Further investigation showed the high-voltage capacitor shorted. I replaced that, but now the control panel doesn't work. Seems like that last fuse-blowing incident caused something else to fail. The 220 volt circuit is OK - the lower conventional oven works fine. I *suspect* the high-voltage portion of the microwave is OK since I replaced the HV capacitor, but the low-voltage digital control panel is inoperative. I can't find 5 volts on it anywhere. Any ideas on what to check would be most welcome. Thanks.
my GE microwave, over the stove model #JVM1850BD 002 does not heat and smells like something burnt, the control panel works
i too have model jkp62g0k3bg no power i replaced the 15 amp fuse and still there is no power please help
Rank: Guest
Groups: Guests
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Originally Posted by: abbotm Originally Posted by: brian anth microwave over stove will not power up. i have250 volts to what looks like the ac/dc power converter but no dc voltage going down to circuit board. Anyone know how to test ? Micro is completely dead I have the same problem with a GE JKP62G K3. First the control panel was dead. Replaced the 15 amp fusestat behind it. The control panel came back to life. I reset the clock - all good. When I started the microwave, the fuse popped again. Further investigation showed the high-voltage capacitor shorted. I replaced that, but now the control panel doesn't work. Seems like that last fuse-blowing incident caused something else to fail. The 220 volt circuit is OK - the lower conventional oven works fine. I *suspect* the high-voltage portion of the microwave is OK since I replaced the HV capacitor, but the low-voltage digital control panel is inoperative. I can't find 5 volts on it anywhere. Any ideas on what to check would be most welcome. Thanks. Originally Posted by: jam1200 i too have model jkp62g0k3bg no power i replaced the 15 amp fuse and still there is no power please help
