My washer control panel was dead. I installed a control panel I purchased from Appliance Parts Pros, and now I get the error code F22 and sometimes F02. What is error code F22? Thanks
see the attachment for the tech sheet. |
THIS FORUM IS DEAD!!!!!!! |
After changing out the door switch, I still get the f22. When I open and shut the door a couple times, it switches to f02. F02 is the drain pump. Are they related?
Not as far as I know. Perhaps you received a faulty board. I would check the connections at the board. |
The CCU is sending the right voltage to the IU, but only the error codes respond when plugging in washer. I can,t run diagnostic.Error codes do cancel when pause/cancel is pushed, but nothing else seem to light or respond. The door switch I bought from appliance parts pros has the same ohm readings as the old one, but not what the manual says they should be. Too many things going on to narrow it down. appreciate the help
