sparks87144
#1 Posted : Friday, August 19, 2011 9:32:10 PM(UTC)
sparks87144
My washer control panel was dead. I installed a control panel I purchased from Appliance Parts Pros, and now I get the error code F22 and sometimes F02. What is error code F22? Thanks
#2 Posted : Saturday, August 20, 2011 7:24:25 AM(UTC)
see the attachment for the tech sheet.
File Attachment(s):
WFW9400.pdf (216kb) downloaded 11 time(s).
sparks87144
#3 Posted : Saturday, August 20, 2011 10:52:14 AM(UTC)
sparks87144
After changing out the door switch, I still get the f22. When I open and shut the door a couple times, it switches to f02. F02 is the drain pump. Are they related?
#4 Posted : Saturday, August 20, 2011 12:58:16 PM(UTC)
Not as far as I know.
Perhaps you received a faulty board.
I would check the connections at the board.
sparks87144
#5 Posted : Saturday, August 20, 2011 2:13:56 PM(UTC)
sparks87144
The CCU is sending the right voltage to the IU, but only the error codes respond when plugging in washer. I can,t run diagnostic.Error codes do cancel when pause/cancel is pushed, but nothing else seem to light or respond. The door switch I bought from appliance parts pros has the same ohm readings as the old one, but not what the manual says they should be. Too many things going on to narrow it down. appreciate the help
error code F22 (Washer Repair)
by sparks87144 8/20/2011 7:48:59 AM(UTC)
by sparks87144 8/20/2011 7:44:42 AM(UTC)
by sparks87144 8/19/2011 9:30:46 PM(UTC)
