First off all the top burners and broiler are fine. The oven burner takes a long time to light and will not stay lit, but will go out and then relight for a few seconds then go out again. Takes very long time to get up to tempture setting, some times never. Any ideas of the cause, igniter, the short or control panel?
If you have an ohm meter, test the ignitors. If they ohm out (3 to 3.5 ohms) the the problem is your valve.
Here's the breakdown CGR3520BDH AP4098213 - valve
Nat
Not to sure I did it correctl, but the ohm were below 3
I think if you replace the ignitor you should be good to go.
Nat
