STRYKER413
#1 Posted : Tuesday, August 16, 2011 1:07:19 PM(UTC)
STRYKER413
first it gave me code pf so i changed the thermistor and now it gives me code f23 but i noticed the igniter does not turn on. Could that be the problem?
#2 Posted : Tuesday, August 16, 2011 3:44:07 PM(UTC)
The "F23" error code means "Shorted thermistor".
Start the timed dry cycle. If after 60 seconds the error code flashes in the display, check the wire connections at the thermistor and the machine control electronics.
If there is nothing wrong, replace the control board.
- The control board Part number: AP3965135
STRYKER413
#3 Posted : Wednesday, August 17, 2011 3:42:23 AM(UTC)
STRYKER413
Thanks Gene it was the thermistor. I replaced it and it's working now. Guess I bought a bad one.
#4 Posted : Wednesday, August 17, 2011 12:46:59 PM(UTC)
We can not rely on new parts anymore. Very bad!!!
