AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Maytag Washer won't drain when it comes to 'spin' cycle
I have a Maytag Washer MAV8551AWW that recently began failing to empty the bin of water when it gets to the final 'spin' cycle. I can bypass this by moving the arrow/knob to another 'spin' cycle on the dial. Just seems to have this problem when we do regular wash/cycle. Seems to be fine as far as emtpying the bin of water when we select a 'quick cycle'. When a regular cycle is done, it ALWAYS stops at the 'spin' cycle. Any ideas on the possible cause to this? Thank you! Andy
This service is awesome! I am 3 for 3 with getting the correct advise. Two unrelated washing machine issues at different times and an issue with a microwave. Each time, I've been provided accurate technical help and the order numbers of peices that I needed. Each time, it's worked out perfectly. Thank you!
Washer Repair
