andyjmatthews
#1 Posted : Sunday, August 14, 2011 5:01:17 PM(UTC)
andyjmatthews
I have a Maytag Washer MAV8551AWW that recently began failing to empty the bin of water when it gets to the final 'spin' cycle. I can bypass this by moving the arrow/knob to another 'spin' cycle on the dial. Just seems to have this problem when we do regular wash/cycle. Seems to be fine as far as emtpying the bin of water when we select a 'quick cycle'. When a regular cycle is done, it ALWAYS stops at the 'spin' cycle. Any ideas on the possible cause to this? Thank you! Andy
magician59
#2 Posted : Monday, August 15, 2011 7:03:25 AM(UTC)
magician59
This sounds like a timer problem.
Part number: AP4027444
andyjmatthews
#3 Posted : Thursday, August 18, 2011 11:53:28 AM(UTC)
andyjmatthews
This service is awesome! I am 3 for 3 with getting the correct advise. Two unrelated washing machine issues at different times and an issue with a microwave. Each time, I've been provided accurate technical help and the order numbers of peices that I needed. Each time, it's worked out perfectly. Thank you!
