jsm1115
#1 Posted : 14 years ago
jsm1115
Whirlpool GU2500XTPQ7 soak & scour light blinks, also Accusense and Normal wash buttons blink alternately. I have tried resetting by pressing Sani-rinse, heated dry, sani-rinse, heated dry. All the lights came on then cycle thru bunch of different sequenses. But in the end the soak & scour light started blinking again and the machine will not operate. I have cut the power and tried again, but same scenario repeats. Also tried the normal wash, heat dry, normal wash, heat dry and when all the lights were lit on the panel I pressed start. The normal cycle started but with in few minutes it stopped and went to blinking soak & scour light again.
Any suggestions? Could it be the panel control or perhaps the control board?
So appreciate your help & suggesitions, thank you!
#2 Posted : 14 years ago
The model number you posted is incomplete. It should be one more letter and a number. Verify and repost it please.
jsm1115
#3 Posted : 14 years ago
jsm1115
Originally Posted by: jsm1115 Go to Quoted Post
Whirlpool GU2500XTP soak & scour light blinks, also Accusense and Normal wash buttons blink alternately. I have tried resetting by pressing Sani-rinse, heated dry, sani-rinse, heated dry. All the lights came on then cycle thru bunch of different sequenses. But in the end the soak & scour light started blinking again and the machine will not operate. I have cut the power and tried again, but same scenario repeats. Also tried the normal wash, heat dry, normal wash, heat dry and when all the lights were lit on the panel I pressed start. The normal cycle started but with in few minutes it stopped and went to blinking soak & scour light again.
The complete model number is GU2500XTPQ7. Thanks again for any help.
Joy M.
jsm1115
#4 Posted : 14 years ago
jsm1115
Model GU2500XTPQ7. Also should mention after pushing the sani-rinse and dry button buttons... "D3" displayed, followed by "04", then "10". Don't know if that helps or even means anything.
Thanks again.
#5 Posted : 14 years ago
Remove the bottom panel and locate the soil sensor (#25 on the diagram). It is mounted on the sump assembly.
Unplug the dishwasher. Open the console and disconnect the keypad ribbon from the control board at P1. Plug the dishwasher back. With the door latched, disconnect and reconnect the sensor two times in less than 6 seconds.
Wait 10 seconds, then monitor the control's response.
Listen for the dishwasher to begin filling after it concludes 5-10 seconds display test at the beginning of the service diagnostics test. If it does it, replace the control panel.
If it would not do it, replace the control board.
Read more: http://forum.appliancepartspros...ing-2.html#ixzz1UreXt9AR
http://forum.appliancepartspros.com
- The control board Part number: AP4309110
If you need the correct part number for the control panel, post the color of it.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GU2500XTPQ7 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
jsm1115
#6 Posted : 14 years ago
jsm1115
Thank you Gene; appreciate your help! Will review the suggested links & try your suggestions this weekend. Thanks again!
Joy M.
#7 Posted : 14 years ago
You are welcome Joy. Keep us posted.
