onemoretime
#1 Posted : Monday, December 15, 2008 1:10:22 PM(UTC)
onemoretime
I just replaced the door seal on my wife's dishwasher and it is leaking more now than it did before the change. Any thoughts or ideas what to do.
Thanks in advance
Doug
#2 Posted : Tuesday, December 16, 2008 12:20:44 PM(UTC)
Doug,
Check if there are suds inside the dishwasher.
onemoretime
#3 Posted : Tuesday, December 16, 2008 6:07:01 PM(UTC)
onemoretime
My wife says no to your question Gene
onemoretime
#4 Posted : Saturday, December 20, 2008 1:59:44 PM(UTC)
onemoretime
Heres an update to my dishwaher leak. I took the door cover off and noticed that the tabs on the seal were not all the way through in a "locked" position, so I used a pair of pliers and pulled them until they appeared to lock against the door. This seemed to pull the gasket tighter on the door so we tried a rinse cycle and it was still leaking but not to the same degree. It appears to be coming out under the little plastic tab on the inside bottom edge of the door, held in place by a couple screws. Is this a replaceable part?
Doug
Guest (4)
