jacchiro
#1 Posted : Tuesday, October 30, 2007 10:49:10 AM(UTC)
jacchiro
I cannot get the temperature settings to stay low on the fridge side of the Arctica unit It jumps up to 49 degrees and rising by itself. How do i get the setting to stay at 36 degrees or so or what should i do now since it is getting very warm. The freezer side seems ok and is at o degrees.
#2 Posted : Wednesday, October 31, 2007 1:57:28 AM(UTC)
Pull freezer back panel and check frost pattern and post results. If totally frozen, thaw out with a hair dryer and check defrost heater and thermostat while still cold.
If ok, check the damper door in the refrigerator upper panel, if door jammed shut,unplug unit and jam door 1/2 open. If the damper door was jammed shut, order a new one.
