garys@abdc-az.com
#1 Posted : Thursday, August 11, 2011 7:07:41 AM(UTC)
garys@abdc-az.com
My Whirlpool duet fills with water when not in use. I know it could be the water inlet valve, but if I unplug the machine it does not fill with water which leads me to believe it's the water level pressure switch.
Any thoughts?
sidfink43
#2 Posted : Saturday, August 13, 2011 9:08:48 AM(UTC)
sidfink43
Well that is unusual. It could either be the water level switch or the control unit. try replacing the water level switch,but I think in the end it will be the control unit.
Guest (4)
