My washer shows no sign of power,the timer will not run any cycles and will not fill with water,any suggestions?:(
Check for continuity between the "L1" & "SW" terminals on the lid switch (#3 on the break down diagram). Replace the lid switch if the circuit is open. - The part number for the lid switch is AP3159413 Here are the break down diagrams for the Maytag Atlantis washer Model MAV7257AWWGene.
I checked the switch,turned out to be bad. Thanks for the help!!!!
I'm glad you were able to fix it. Happy Holidays!
