boshkey58
#1 Posted : Monday, August 8, 2011 8:54:32 AM(UTC)
boshkey58
My built in microwave started do not not heat our food completely and we smell a electrical smell sometimes...what is the problem? Could it be the stirrer belt?
SPC_IC
#2 Posted : Monday, August 8, 2011 12:53:33 PM(UTC)
SPC_IC
I would suspect the high voltage section. Probably not the transformer as that parts tends to smoke heavily and smell of burnt copper when bad. Diode and magnetron have a burnt plastic type smell. A high voltage problem is usually accompanied by an unusual noise and no heat at all in most residential units. I would start by checking for visual signs in the high voltage section.
