sandy lb
#1 Posted : 16 years ago
sandy lb
whenever turn stove on the broiler comes on too broiler will not turn off
have to turn the circuit breaker off. Do i need to replace the stove???
or do i need to replace control panel?
#2 Posted : 16 years ago
Sounds like the problem is a bad control board. What is the complete model number of the range?
str8shootin
#3 Posted : 14 years ago
str8shootin
Frigidaire # FEF336ASC broiler will not shut off any help would be appreciated
#4 Posted : 14 years ago
srt8shootin
Replacement parts for FRIGIDAIRE FEF336ASC Frigidaire/electric Range | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316255152.pdf
Unfortunately the same as the original poster, the control board Item 20 in Section 1.
