sandy lb
#1 Posted : Saturday, December 13, 2008 11:32:46 PM(UTC)
sandy lb
whenever turn stove on the broiler comes on too broiler will not turn off
have to turn the circuit breaker off. Do i need to replace the stove???
or do i need to replace control panel?
#2 Posted : Sunday, December 14, 2008 7:33:53 PM(UTC)
Sounds like the problem is a bad control board. What is the complete model number of the range?
str8shootin
#3 Posted : Friday, April 22, 2011 11:26:04 AM(UTC)
str8shootin
Frigidaire # FEF336ASC broiler will not shut off any help would be appreciated
#4 Posted : Friday, April 22, 2011 12:45:41 PM(UTC)
srt8shootin
Replacement parts for FRIGIDAIRE FEF336ASC Frigidaire/electric Range | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316255152.pdf
Unfortunately the same as the original poster, the control board Item 20 in Section 1.
Guest (5)
